August 30, 2012, 20:12 |
convergence problem
navid
I have problems in getting convergence for an unsteady simulation. the continuity residuals do not fall down below 4*10^-3. changing URF's does not make a difference. what surface monitors can I use to check convergence? since there is no steady state solution for my problem, every quantity like pressure and velocity will change in domain. how can I deduce convergence from surface monitors? Below is the picture of the residuals. any ideas? |
August 31, 2012, 15:48 |
Jared Brewer
It is going to depend on your simulation. Typically, I monitor mass/volume flow rates across boundaries. Unsteady simulations are usually a little more difficult to judge convergence based on residuals.
September 1, 2012, 03:07 |
navid
I don't have any mass flow rate. my problem is a bubble collapse simulation. I cannot check pressure or velocity in domain since it is changing constantly. I don't now if my simulation is converged or not?
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 06:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 03:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 00:24 |
