July 18, 2022, 15:49 |
Compute canada / batch file / journal file
PENANG
Rep Power: 8 |
Hello everyone,
I want to run Fluent unsteady airfoil cases using compute Canada clusters. I am using the batch files and journal files attached. However, my cases are not running successfully. Please help me accordingly. Journal File ; SAMPLE FLUENT JOURNAL FILE - UNSTEADY SIMULATION ; ---------------------------------------------- ; lines beginning with a semicolon are comments ; Write case and data files in legacy format: /file/cff-files no ; Read input files (FFF-in.cas and FFF-in.dat): /file/read-case-data S45.cas ; Write a data (and maybe case) file every 100 time steps: /file/auto-save/data-frequency 100 /file/auto-save/case-frequency if-case-is-modified ; Write to output sub-directory (appends flowtime and timestep) /file/auto-save/root-name output/S45-out ; ##### Settings for Transient simulation : ##### ; Set the magnitude of the (physical) time step (delta-t) /solve/set/time-step 0.0001 ; Set the max number of iterations per time step: /solve/set/max-iterations-per-time-step 20 ; Set the number of iterations for which convergence monitors are reported: /solve/set/reporting-interval 1 ; ##### End of settings for Transient simulation ##### ; Initialize using the hybrid initialization method: /solve/initialize/hyb-initialization ; Perform unsteady iterations for a specified number of time steps: /solve/dual-time-iterate 2450, ; Overwrite output files by default: /file/confirm-overwrite no ; Write final output file (FFF-out.dat): /file/write-data S45-out ; Write simulation report to file (optional): /report/summary y "My_Simulation_Report.txt" ; Exit fluent: "unsteady_simul.jou" 24L, 603C 1,1 Top Journal File .JOU #!/bin/bash #SBATCH --account=XYZ # Specify account #SBATCH --time=00-03:00 # Specify time limit dd-hh:mm #SBATCH --nodes=1 # Specify number compute nodes (1 or more) #SBATCH --cpus-per-task=64 # Specify number cores per node #SBATCH --mem=0 # Do not change (allocates all memory per compute node) #SBATCH --ntasks-per-node=1 # Do not change #SBATCH --job-name=fluent #~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ # Remember to edit the journal file journal_file=unsteady_simul.jou # Adapt to your input solver=2ddp #~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ module load StdEnv/2020 # Applies to all clusters module load ansys/2021R2 # Or newer module versions slurm_hl2hl.py --format ANSYS-FLUENT > machinefile-$SLURM_JOB_ID "submit_fluent_bynode.sh" 25L, 955C 1,1 Top Thank you. Regards, |
July 19, 2022, 01:00 |
Alexander
Rep Power: 34 |
check log file generated in your working folder
however, prorpably your problem is here Code:
; Exit fluent: "unsteady_simul.jou" 24L, 603C 1,1 Top is not a TUI command
best regards ****************************** press LIKE if this message was helpful |
July 19, 2022, 11:37 |
PENANG
Rep Power: 8 |
Hi Alex, Thank you for your reply. Yes, the message file shows:
/var/spool/slurmd/job7718886/slurm_script: submit_fluent_bynode.sh: command not found Can you please how I can submit the file because I need to update it to read the journal file? Thank you. |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
