September 5, 2012, 23:15 |
I can't mesh my geometry, Need help
Theerawat
Rep Power: 13 |
Hi guys thank you for looking my problem.
I use workbench to import geometry form solid work and mash it. I got problem in meshing. The program didn't mesh it for me, it said "The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology" and WA mesh could not be generated using the current meshing options and setting." I tried to Fine in relevance center but it didn't work. Could you guys help me ? thanks |
September 6, 2012, 02:48 |
Rep Power: 14 |
What you need to do is tutorials about meshing. If you are stuck on that point, im sorry but clearly you need to learn more.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] Mesh a geometry without stl file | eysteinn | OpenFOAM Meshing & Mesh Conversion | 0 | May 5, 2011 10:15 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
