monitoring of displacement during fall of a body
Old   October 8, 2009, 01:03
Default monitoring of displacement during fall of a body
Deepti.R.Krrishnan
Deepti is on a distinguished road
hi,
i am using the tutorial for the 2d falling box. i want to get the displacement monitoring for the box. is it possible to get a plot of it in fluent as we get for pressure ,velocity etc...
thanks for all the inputs.
deepti
Deepti is offline   Reply With Quote
Old   October 8, 2009, 02:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I assume you can only do that with UDF. (is the tutorial running with an udf?)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 8, 2009, 02:51
Deepti.R.Krrishnan
yes,i am using the cg udf. isnt the udf meant for giving properties to the physicals phenomenon? can i include the kind of solution that i need to extract? is it possible to define a custom function? i tried doing it. but i couldnt incorporate the flow time variable.
thank you for the inputs.
Old   October 8, 2009, 04:14
-mAx-'s Avatar
Maxime Perelli
i don't know this tutorial, but cg udf sounds like "center of gravity". It should be an 6dof motion, so I assume you can extract the displacement in a file.
just like in this udf (no 6dof motion):
#include <stdio.h>
#include "udf.h"
#if !RP_NODE
# define UDF_FILENAME "udf_loc_velo"
# define UDF_DATA "data.dat"
/* read current location and velocity from file */
static void
read_loc_velo_file (real *loc, real *velo)
FILE *fp = fopen(UDF_FILENAME, "r");
if (fp != NULL)
float read_loc, read_velo;
fscanf (fp, "%e %e", &read_loc, &read_velo);
fclose (fp);
*loc = (real) read_loc;
*velo = (real) read_velo;
else
*loc = 0.0;
*velo = 0.0;
/* write current location and velocity in file */
static void
write_loc_velo_file (real loc, real velo)
FILE *fp = fopen(UDF_FILENAME, "w");
if (fp != NULL)
fprintf (fp, "%e %e", loc, velo);
fclose (fp);
else
Message ("\nWarning: cannot write %s file", UDF_FILENAME);
/* write current location and velocity in datafile */
static void
write_data_file (real time, real loc, real velo, real force)
FILE *fp = fopen(UDF_DATA, "a+");
fprintf (fp, "%e %e %e %e\n", time, loc, velo, force);
fclose (fp);
#endif /* !RP_NODE */
DEFINE_ON_DEMAND(reset_velocity)
#if !RP_NODE
real loc, velo;
read_loc_velo_file (&loc, &velo);
write_loc_velo_file (loc, 0.0);
Message ("\nUDF reset_velocity called:");
#endif
DEFINE_CG_MOTION(valve, dt, cg_vel, cg_omega, time, dtime)
#if !RP_NODE
Thread *t = DT_THREAD (dt);
face_t f;
real force, loc;
#endif
real velo;
/* reset velocities */
NV_S (cg_vel, =, 0.0);
NV_S (cg_omega, =, 0.0);
if (!Data_Valid_P ())
return;
#if !RP_NODE
/* compute force on piston wall */
force = 0.0;
begin_f_loop (f, t)
real *AA;
AA = F_AREA_CACHE (f, t);
force += F_P (f, t) * AA[0];
end_f_loop (f, t)
# if RP_2D
if (rp_axi)
force *= 2.0 * M_PI;
# endif
/* add in spring force */
# define K_SPRING 253.18
real init_disp = 0.02791;
real s_force = K_SPRING * (loc + init_disp);
force = force - s_force;
/* compute change in velocity */
real dv = dtime * force / 0.0217;
velo += dv;
loc += velo * dtime;
Message ("\nUDF valve: time = %f, x_vel = %f, force = %f, loc(m)= %f\n",
time, velo, force, loc);
write_loc_velo_file (loc, velo);
write_data_file (time,loc,velo,force);
#if PARALLEL
host_to_node_real_1 (velo);
#endif
cg_vel[0] = velo;
DEFINE_CG_MOTION(moving_fluid, dt, cg_vel, cg_omega, time, dtime)
#if !RP_NODE
face_t f;
real force, loc;
#endif
real velo;
return;
#if !RP_NODE
#if PARALLEL
#endif
cg_vel[0] = velo;
Old   September 4, 2012, 03:31
vahid
vahidss is on a distinguished road
Fluent user guide (6DOF) :
Note that you can also keep track of an object's motion history using the text user interface and by entering yes for the motion-history? text interface command.
define -> models -> dynamic-mesh-controls-> six-dof-parameter->
motion-history?
vahidss is offline   Reply With Quote
Monitoring Torque on rotating body in MRFSimpleFoam mahendra OpenFOAM Running, Solving & CFD 41 March 18, 2019 21:08
Free fall body simulation velan OpenFOAM Running, Solving & CFD 5 July 31, 2010 13:23
how to use Total Mesh Displacement for making a subject translating and rotating? snailstb CFX 3 September 16, 2009 04:06
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 08:54
velocity of a body fall. th. viscous medium sohrab arora Main CFD Forum 3 September 11, 2001 22:33
