March 22, 2012, 08:09 |
radiation heat transfer
Georg
I have defined a simple plane model made of a transparent solid material (Energy/DO-model). At one side, a Wall boundary condition with mixed thermal conditions is assigned. The radiation BC type is "opaque". According to the given boundary condition, I have computed the Total Heat Transfer q and the Radiation Heat Transfer (RHT) q_str. A comparison with the values obtained with "Reports>Fluxes> ... Heat Transfer Rate" shows a good agreement regarding the Total Heat Transfer Rate. But the Fluent-result for q_str is about 15 % larger than the value given by "A eps sig (T_infinity^4-T_w^4)" (A is the area of the side with the Wall boundary condition). So my question is: How does Fluent the Radiative Heat Transfer Rate compute? Another question: Is there a possibility to get the Radiation Heat Transfer Rate for a specific surface and for a given Wavelength Interval (in a Non-Gray Model)? Thanks and best regards. |
September 5, 2012, 14:56 |
Negin Nazarian
Rep Power: 14 |
Hi
I have a same problem as you. Have you figure out how does Fluent compute the Radiative Heat Transfer? Cheers Negin |
Heat transfer, convection, radiation, conduction | Sandra H. | OpenFOAM | 1 | March 3, 2010 08:02 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Conjugate heat transfer and radiation modeling questions | shankara.2 | FLUENT | 0 | April 21, 2009 15:55 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Radiation Heat Transfer | The IFRF Heat Transfer Team | Main CFD Forum | 0 | January 31, 2000 14:02 |
