September 6, 2012, 03:42 |
time dependent source term
Dr. Moloy Kumar Banerjee
Rep Power: 14 |
Dear all,
I am trying to solve the effect of body acceleration on the human arterial system. For that I need to write some codes for a time dependent source term in DEFINE_SOURCE Macros. The acceleration term is given by a(t) = a0*Cos(omega*t+Phi), where a0 is the amplitude part of the acceleration in mm, but the Fluent document tells that the dimension of the source term should be in N/m^3. How to make the proper dimension for the problem. |
September 6, 2012, 07:37 |
Rep Power: 14 |
Dear Amir,
Thanks for your response.Is there is any problem if my source term contains only time as a variable other than any space co ordinate? and in that case dS[eqn]=0, is it correct or not? N.B: Could you provide me your mail id please for further help... Thanks in advance |
September 6, 2012, 10:05 |
#4 | |
But about dS, it's not right. This term prescribes the derivative of the source term respect to the desired variable which you're considering its transport equation. e.g., if you're introducing a source term for x-momentum equation, the dS[eqn] would be 0 if the source is not a function of Ux. It's not about spacial variables. (refer to the UDF manual) Bests,
Amir |
Display Modes | |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 11:03 |
How to add a time dependent source term to icoFoam? | kirikù | OpenFOAM | 2 | March 23, 2014 21:24 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
UDF: source term dependent on location | Vladimir Krejci | FLUENT | 0 | April 2, 2003 09:38 |
