Boiling with fluent
Like Tree1Likes
  • 1 Post By Jan Rusås
Old   October 4, 2004, 03:06
Default Boiling with fluent
Jan Rusås
Dear Fluent Users,
I a new to Fluent and I am not aware of the capabilities of Fluent for calculating boiling flow.
I have a problem similar to a pot boiling water. I would like to predict the amount of steam generated and the amount of droplets carried with the steam.
I imagine this is difficult but any hints to capture global trends would be fruitfull. The most important aspect is to predict the water droplets.
Thanks in advance Jan Rusås
Old   October 4, 2004, 08:13
Default Re: Boiling with fluent
Jan Rusås
I have found the 2 tutorials Horizontal film boiling and Heat and mass transfer with the Mixture model. I will investigate the possibilities though those, but any comments,hints or experience is very welcome
Old   May 23, 2011, 22:49
Raúl
rlamadri is on a distinguished road
hi Jan
I'm trying to model evaporation but i haven't fount much information yet. My license has finished, so I don't have access to the fluent customer portal. Could you sent me those tutorials or any aditional information, my email es rlamadri@gmail.com.
thanks
Raúl
rlamadri is offline   Reply With Quote
Old   June 18, 2011, 23:45
Default Boiling
digvijay
digvijay8911@gmail.com is on a distinguished road
If you have "heat and mass transfer with mixture model tutorial and source.c udf file" please send me. Thank you.
digvijay8911@gmail.com is offline   Reply With Quote
Old   June 22, 2011, 12:47
digvijay
I have found the tutorial Heat and mass transfer with the Mixture model.
If you have udf source.c file of above tutorial then please email me. My email id is digvijay8911@gmail.com.
Thank You.
Old   September 9, 2012, 05:32
Default Help Needed
STEPHEN BONG
Stephen Bong is on a distinguished road
Dear Jan,
Could you please forward a copy of your tutorial to me at stephenbongpy@gmail.com as I'm new to FLUENT and need it for my current project. Thanks a lot for your kind considerations and attention.
Best Regards,
Stephen
Stephen Bong is offline   Reply With Quote
Old   September 9, 2012, 15:37
samiullah
samidabest is on a distinguished road
( i make the 2d model of shell and tube heat exchanger and mesh it but when select heat exchanger model in fluent it give error that primary and auxiliary regions are not overlapping ..... so plz help me what i do .... i'm new to use ansys
samidabest is offline   Reply With Quote
bubble diameter definition in multi phase flow boiling simulation FLUENT Abishek FLUENT 13 July 1, 2019 12:12
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
