Conjugate Heat Transfer Problem
Old   January 9, 2013, 05:40
Default Conjugate Heat Transfer Problem
Paritosh Vasava
vasava will become famous soon enough
I am simulating hot air flowing over a steel plate in Fluent. The geometry is 2D consisting of two layers one for air (with inlet, outlet) and other is steel plate. The incoming air is at 100 C and it is suppose to heat the steel plate.
I have created geometry and mesh (with interfaces for heat exchange). However I do not see any heat transferred from air to the steel plate.
If I am trying to heat a plate with hot air, it is forced convection. Am I right.
Any comments of suggestions for fluent simulations.
vasava is offline   Reply With Quote
Old   January 10, 2013, 01:46
SSL
msaeedsadeghi is on a distinguished road
Conjugate heat transfer settings will be setted by default. So I think there is a problem with your mesh and interfaces.
msaeedsadeghi is offline   Reply With Quote
Old   January 10, 2013, 02:28
Paritosh Vasava
Thank you Saeed
I have made sure that the interface is set correctly. I tried with the interface which is set 'by default' by Ansys Mesh and manually. Nothing seem to work.
For the domain (2D) of dimension 1000 mm x 25 mm, I have 100000 quadrilateral elements.
Right now I doubt if a steel plate can be heated by hot air to 120 C (by natural convection). To do this it could take a long time.
Again correct me if I am wrong.
Old   January 11, 2013, 01:52
Paritosh Vasava
Everything is ok now. I could solve the issue with use of turbulence model and one refinement of mesh.
Thank you Saeed for your reply.
conjugate heat transfer, fluent, forced convection
Mesh suggestions for a conjugate heat transfer problem maddalena Main CFD Forum 1 January 25, 2013 17:39
Conjugate heat transfer ali_1364reza CFX 3 May 30, 2012 07:42
Heat transfer problem seojaho CFX 6 May 6, 2010 00:32
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
Heat Transfer Problem Help JB FLUENT 2 October 18, 2006 18:54
