Dynamic mesh issue
1 Attachment(s)
Dear all,
I am trying to simulate the flow through a artery in the presence of stenosis with surface irregularities. The artery wall is assumed to oscillate with a velocity of sinusoidal variation. In order to define the motion of the wall I am using the Dynamic mesh feature of Fluent with the following compiled udf to define the motion of the wall. #include "udf.h" DEFINE_CG_MOTION(wave, dt, vel, omega, time, dtime) { vel[1]=-.0001*7.543*sin(7.543*time); } For the unsteady simulation I am using a time step size of 0.0001 sec and as a mesh method I am using Layering approach with a split and collapse factor of 0.4 and zone type as rigid body. But unfortunately when I try to run the simulation it shows the error Update-dynamic mesh failed: negative cell volume detected. Please help me. |
try reducing your time step size and also play with dynamic mesh parameters, also turn on smoothing
Dear cfd seeker
thanks for your reply. I have already reduced the time step upto 0.000001 sec, but till the same problem exists.Regarding the parameters how to choose the proper value of those. |
Try using triangular mesh and use re-meshing instead of layering.
If you insist on going with quad mesh try the following 1. Set the udf motion for the fluid (the quad mesh region) 2.Set the boundary as stationary. |
dear nimbus1947
how to set the udf motion for the fluid zone and what is the stationary boundary. Would u please elaborate something? |
upload the picture of your full domain with boundary names.
Hi guys
Cell height of wall (in dynamic mesh zones) must not be zero. or you must use another wall as stationary and also quad zone must be move with same udf. |
