Fluent Case-File saved in parallel/serial
Dear all,
I got a question concerning case-files in batch jobs. If I want to run a simulation as a batch job parallel at several cores, does it make any difference for may simulation results whether my case-file was saved in parallel or serial mode during the simulation set up before? Thanks a million for any help! Lilly |
I'm not expert for batch jobs, but I usually save my cas file as serial and then open and calculate in parallel mode; so I think you will not have any problem..
Hi Lilly,
I've never had problems either: serial, parallel, different number of cores, batch mode... everything works for me. Marion. |
Dear Marion, dear Daniele,
that sounds good! Thank you for your help! Lilly |
