Convergence problem?
Old   August 21, 2014, 23:48
Exclamation Convergence problem?
Johann
jacs_lokoo is on a distinguished road
Hello, this is my first post, i'm actually a new user to ANSYS FLUENT.
I'm in the design process of an airfoil, i did my mesh(ICEM) and the quality tells me i'm over 0.8 in all the mesh.
When i run the FLUENT analysis, it always converges on 0 to 12° AoA, even though i think i'm wrong the AoA vs Cl plots a very nice curve.
I don't really know if that's correct.
I used Trans SST coupled and second order upwind with pseudo transient active. When iterating approximately at 160 to 180 it converges, the residuals also converge.
help pls
jacs_lokoo is offline   Reply With Quote
Old   September 15, 2014, 17:20
Default hi johan
rahul kumar
R4RAHUL is on a distinguished road
may be you can decrease your time step-size or select as adaptive instead of fixed and convergence also depends on courant number so you can check that as well
R4RAHUL is offline   Reply With Quote
convergence fluent, convergence issues, convergence problem, convergence problems, mesh and grid
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Force can not converge colopolo CFX 13 October 4, 2011 22:03
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
