Turning supersonic flow into subsonic
Old   September 5, 2012, 04:58
Default Turning supersonic flow into subsonic
Alexander
Salexv is on a distinguished road
I have a supersonic converging-diverging inlet system using external and internal compression system.
My initial flow is Mach 3 and therefore, of course the flow throwout the whole inlet is supersonic.
I am trying to achieve a subsonic outlet of the inlet by increasing the pressure outlet. But it doesn't work because in supersonic flows, Fluent doesn't consider outlet pressure.
So how can I force the flow to become subsonic even though I can't change the pressure outlet?
Thanks
Salexv is offline   Reply With Quote
Old   September 5, 2012, 07:51
eng_s_sadeghi's Avatar
eng_s_sadeghi is on a distinguished road
You can not force the outlet to achieve a pressure. Flow regime defines what should happen at the outlet
Saeed Sadeghi
Ansys Fluent CFD Consultant
eng_s_sadeghi is offline   Reply With Quote
Old   September 5, 2012, 08:08
Alexander
Thank you for your response.
So what you are saying is that there is no way to receive a supersonic inlet with a subsonic outlet (having a normal shock in the diverging part of the system)? In any way possible?
Old   September 5, 2012, 08:34
It depends just on boundary condition (not outlet) and geometry.
Saeed Sadeghi
Old   September 5, 2012, 08:42
Alexander
What condition do you think should I enter on the outlet? Tried changing it into "pressure inlet" and it didn't help.
Old   September 5, 2012, 11:17
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The problem is that in a supersonic flow, the flow field is not affected by the conditions downstream. Thus, the flow field in a given geometry is independent of the values you try to specify at the outlet.
Your only chance (if the upstream values are fixed) is to change the geometry.
flotus1 is offline   Reply With Quote
Old   September 23, 2012, 09:35
Alexander
Can someone help me please with this problem?
I've seen few works that managed to apply a high pressure outlet in a supersonic inlet, but couldn't reach the authors.
Does anyone know how to enforce it in FLUENT?
Thanks
Old   September 23, 2012, 20:10
Syavash Asgari
syavash is on a distinguished road
Thanks
Hi Alexander,
I have a similar problem and I couldn't manage to find a solution.
There is an image of the geometry and Mach contours that I upload here.
How is it possible to get this solution?! Anyone knows it?
syavash is offline   Reply With Quote
converging, diverging, subsonic, supersonic
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 18:01
Producing a supersonic flow in a constant diameter cylinder clgs.1903 FLUENT 12 May 24, 2012 13:41
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
subsonic inlet or supersonic inlet? mali CFX 0 November 28, 2008 20:57
