Question regarding surface integrals.
Like Tree2Likes
  • 1 Post By jsm
  • 1 Post By jsm
Old   February 24, 2015, 13:02
Default Question regarding surface integrals.
techctrl is on a distinguished road
If a surface integral value (such as pressure) is negative, what does it imply?
If I generate a force report in the positive Y direction for two horizontal walls, the vector value of one is positive and the other is negative. But the surface integral values of both (which are scalar values) are negative.
This has me confused, any clarification provided would be appreciated.
techctrl is offline   Reply With Quote
Old   February 26, 2015, 16:47
jsm
JSM
jsm is on a distinguished road
You are comparing pressure and force that are entirely different. Don't compare the signs of these properties.
Pressure is scalar quantity and it has no signs. In general, fluent will show gauge pressure and it will not add the operating pressure. If it is confusing you, then plot the absolute pressure instead of static pressure. And the most possible reason for negative pressure is re-circulation nearer to the walls.
In other hand, force is vector quantity and what ever the sign you are getting in Fluent is the force acting direction.
techctrl likes this.
With regards,
JSM
jsm is offline   Reply With Quote
Old   February 27, 2015, 00:44
Originally Posted by jsm View Post
Thank you for the explanation.
You are correct that I shouldn't compare a scalar and vector quantity. I was mostly just curious as to why the pressure values end up being negative, which you clarified for me.
One more thing; does the pressure force on a wall surface and the pressure distribution on that same wall act in the same direction? If I were to draw the pressure profile on a wall surface, it should be in the same direction as the force vector, yes?
Old   February 28, 2015, 10:15
jsm
JSM
It is difficult to answer without considering the shape of wall and that is the reason we are using software to understand it.
With regards,
JSM
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 04:31
Worng values reported in surface integrals yashmash FLUENT 1 July 11, 2012 04:04
free surface flow simulation question Jane Main CFD Forum 0 April 22, 2004 13:25
