Home > Forums > FLUENT
dymanic mesh does not work!!!
Old   October 3, 2012, 01:54
Default dymanic mesh does not work!!!
chiwonkim
chiwonkim is on a distinguished road
hello,
i have strugle with dynamic mesh problem.
i need to analyze the oscillating plate in a speaker.
To do this, I used dynamic mesh with 'DEFINE_GRID_MOTION' udf.
The motion works well, but mesh problem occurs.
Although layering (split factor = 0.4, collapse factor = 0.2) option was activated the mesh did not created or destroied, just stretching.
how can i solve this situation?
i captured my problem and attatched it.
my dynamic mesh zone setting follows
1. air : rigid body (zero velocity CG motion) <- i doubt this setting
2. right boudnary(oscillating) : udf('DEFINE_GRID_MOTION' )
please, allow to know me.
thank you
chiwonkim is offline   Reply With Quote
Old   October 3, 2012, 06:30
Vaze
mvee is on a distinguished road
Hi
Can you specify the face significance - how does it behave and move.
First of all create block mesh to use layering option.
If the motion is like piston-cylinder then specify top and/or bottom face as deform. Also specify UDF to right face. This should work. No need to define any condition for air domain.
Best wishes
Mvee
mvee is offline   Reply With Quote
Old   October 6, 2012, 09:29
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
hi mate
recheck the dimensions.
for example if cell dimension near moving wall is 1cm*1cm, you should adjust "Cell Height" value in meshing options to 1cm.
sadjad.s is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Gambit problems Althea FLUENT 21 February 6, 2001 08:05
