-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Analysis of Wind turbine blade ( 3D aerofoil) by Ansys 12 (https://www.cfd-online.com/Forums/fluent/107780-analysis-wind-turbine-blade-3d-aerofoil-ansys-12-a.html)
rsskarthikeyan October 7, 2012 03:12
Dear Friends,
I modeled the wind turbine blade by using Solid works software and kept that files in IGES format. Now i want to analysis the pressure distribution across the wind turbine blade. Kindly suggest me the step by step procedure and tutorials. I have installed Ansys 12 version. thank you
mhossain October 13, 2012 14:21
I have the same need for my simulation... If any one can give us some direction, tutorial or link it will be very helpful for us....
Thank you
syavash October 13, 2012 14:36
The first step is mesh generation in a software like Gambit, this step is very time consuming. Then you should proceed to the next step which is solving flow numerically in Fluent.
mhossain October 13, 2012 14:47
Thanks you so much, but i want to learn the post processing of my results
syavash October 13, 2012 14:50
If you already have solved the problem, the rest is very simple. Please explain what you've achieved and what you're looking for.
rsskarthikeyan October 13, 2012 22:29
want to know various AOA
friend i solved by laminar flow method. So many methods are there. actually im going to analysis as wind turbine blade, which method is suitable ? i want to take result of pressure distribution for various angle of attack ? where i can enter the angle of attact ranges
