Q: Airfoil Low Reynolds
I am design wind turbine 1KW. So I need to simulate predict airfoil in low reynolds. I used NACA 0012 for test. I want to know:
1/ In low reynolds you will use unsteady or steady for time. 2/ Why did my coefficient drag decrease follow time when I use k-epsilon in condition unsteady? I think it will oscillate at a point. |
1- You should use steady scheme to analyze your problem. 2-Oscillation during solution convergence is a common thing for aerodynamic coefficients. Bests. |
How low is your Re...? You might be better to use a Low Re k-e model.
