October 29, 2012, 14:38 |
Injections
Rep Power: 13 |
I am trying to inject small particles of carbon into a 2D room. I have two inlets, both in the bottom left of the rectangle and the outlets are on the top and right side. One is on the bottom and one is on the side. I set the particle to carbon with a diameter of 1m. When I do this, shouldn't I be able to see the particles drop to the bottom because of how big they are? When I change the particle size from 1m to 1e-09m, they both follow the same trajectory. In reality, the big particle should fall to the floor while the small one would follow the flow of air and I'm not sure why I am unable to see this happening.
When I plot the particle and fluid I plot the velocity stream function to see the paths and they both follow one another. For my injection, I chose carbon to be inert and release from both inlets. I checked scale flow rate by face area and inject using face normal direction. Sorry if this is a bit confusing. Any advice would be greatly appreciated. Thanks. |
Injections in cyclone with DPM | arjun3020 | FLUENT | 7 | October 30, 2014 21:01 |
DPM Injections | ABK | FLUENT | 14 | August 26, 2013 02:40 |
Defining DPM Particle Injections with a UDF | TedBrogan | FLUENT | 0 | April 18, 2011 16:45 |
Coal Injections problem | Carlo | FLUENT | 0 | September 30, 2009 06:15 |
DPM injection | ritmat | FLUENT | 6 | June 26, 2007 02:38 |
