Help Needed for FLUENT setup in removal efficiency
Hi guys,
I am new to FLUENT, but my project requires using it to demonstrate a CFD on removal efficiency on a model. The model is inside a pipe, and first create a vortex, then using baffles to remove some of the particulates in the gas stream. I could mesh my model, but I have difficulties in setting it up. The particulates are metal oxides, and about 20% wt in the stream, the stream is just air. Pressure drop through the pipe is less than 1 psi. Length of pipe 8ft. Your answers are highly appreciated. |
| All times are GMT -4. The time now is 20:49. |
