-   -   Shear stress fluctuations by turbulent flow (http://www.cfd-online.com/Forums/fluent/107997-shear-stress-fluctuations-turbulent-flow.html)
Meegao October 11, 2012 05:54
Dear all:
I am trying to plot the shear force as a function of flow time on & near a flat plate at a fixed point. The flow in contact with the plate surface is turbulence therefore I am expecting random time history because the flow velocity of a turbulent flow should be random. However my CFD result shows a quite smooth sin wave.
Its a 2D simulation, I used k-e model, standard wall treatment, no slip, Re=3.6e6, Simplec method and second order for every option. sufficiently small time step, the mesh is ok and I got reasonably good Cl and Cd results in the steady case. For the unsteady simulation I have two monitor points one on the plate and one slightly above. The point-velocity time history for both points follow the same trend (sin wave) with only a little differences in magnitude.
I was hoping to see some randomness and I have been stuck for days. any input on this matter from you guys is much appreciated!:(
