-   -   Results of a Flow in a duct, need confirmation (http://www.cfd-online.com/Forums/fluent/108057-results-flow-duct-need-confirmation.html)
buxZED October 13, 2012 12:39
1 Attachment(s)
Hi all,
This is my first time using CFD
And below is a result I generated for a simple flow inside a duct. Can someone confirm this looks ok/ appears to be correct?
Attachment 16156
Parameters I used are given below
Air Velocity - 10 m/s
Air Temperature - 20 oC
Height of Blocks - 0.04 m
Height of inlet - 0.2 m
Height of outlet - 0.286 m
Distance between expansion & B1 - 0.4 m
Distance between B1 and B2 - 0.2 m
Length of inlet & expansion/ Length of B2 & outlet - 0.6 m
Radius of curved edge - 0.04 m
left wall inlet, opposite wall is the outlet
two blocks are kept at constant temperature
rm123 December 2, 2012 20:43
I thin you should ask Dr. Reza about it. He will tell you if it is correct or not?:p
