February 25, 2004, 21:17 |
DPM Parcel Number Problem
Hi all,
I am currently using a DPM model to simulate particles within a bubble column. My problem is with the DPM injection, despite changing factors like size, mass flow, and time step, Fluent always seem to inject 272 parcels per time step (even if the no. of particles per parcel is less than 1). I haven't bee able to change it. How is this done, what am I missing!! Thanks in advance Shane |
May 19, 2011, 22:40 |
viva
Rep Power: 15 |
Hi, could you please help me with understanding the DPM parcel concept.
How do you find , how many particles are there in the parcel and can the user change the number of particles in one parcel. Thanks in advance |
May 20, 2011, 01:13 |
alighaffari
Rep Power: 14 |
Hi shane
what is your injection type? I guess it is surface injection type. If you create a surface injection, a particle stream will be released from each facet of the surface and so it only depends on your number of mesh in that surface. I think it will be better to use group injection type therefore you can control number of injection streams. For more information see chapter22 of fluent 6.3 users guide. |
May 20, 2011, 11:52 |
viva
Rep Power: 15 |
Hi Amir:
Could you please elaborate a little on how to create virtual surfaces and how to create sample points? Is there any reference that can help me to understand this? Thanks for your help. |
May 20, 2011, 12:00 |
#6 | |
surface->plane ; toggle on bounded and sample points & set sample density set this surface in injection panel. you have particles in each sample point instead of boundary faces. |
May 20, 2011, 13:44 |
viva
Rep Power: 15 |
Thanks Amir.
October 25, 2012, 08:24 |
Mori
Rep Power: 13 |
Hi
I still don't understand how to change the number of particles in a parcel!! would you describe a little more thanks, |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
Problem with DPM interaction in a coal burner | Nando | FLUENT | 1 | April 17, 2007 04:46 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
