October 19, 2012, 07:03 |
Displaying heat flux within solid
Venkat
Rep Power: 13 |
I am doing Conjugate Heat Transfer problem in Fluent. I have couple of solids which are in thermal contact with each other, and some of them are in contact with Fluid. I want to be able to plot heat flux vectors within solids to visualize the heat flow. I can plot it at the interface between Solid/Fluid zones in Fluent. But not able to plot anything other than temperature for/within Solids. Is there a way that I can plot in Fluent? For your information, when I did pure conduction analysis in Ansys thermal, I was able to visualize the flow of heat within solids, and it is nice to understand how is the direction of heat flow. Please help me if you can. Thanks in advance. Venk |
October 20, 2012, 13:19 |
Rep Power: 15 |
No you can't. As there is no flow on a solid, it just shows statics.
Saeed Sadeghi Ansys Fluent CFD Consultant |
cht, cht coupling, heat flux, post procesing |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
heat flux at fluid solid interface | Studentdrak | CFX | 6 | January 30, 2012 11:05 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
heat conducting in a solid domain | Rogerio Fernandes Brito | FLUENT | 0 | March 18, 2008 17:25 |
