October 18, 2012, 05:22 |
set solid volume fraction in 2D
Rep Power: 14 |
Hi.
I am confused how can set some parameters in 2D problems: e.g.: the real problem is a cylinder 3D with volume of 20 cm3. We fill this cylinder with 16 g of powder, density of 1.6 g/cm3. So the solid volume fraction is 0.5. My question is: when we simulate the 2D problem, what would be the solid volume fraction? best regards, |
October 18, 2012, 05:56 |
Fariborz Soroush
Rep Power: 16 |
I think you have 2 choices:
1- simulate a sector. e.g. 10 or 30 degree of the cylinder 2- usually some cases were studied by the others with some reduction in dimensions, in my case of research equivalent area for holes are normal. You have to find them and check. |
2d problem, solid volume fraction |
volume fraction in mixture model and VOF???? | multiphase-flow | FLUENT | 4 | August 7, 2014 10:35 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Estimation of "inlet solid volume fraction"...? | Genanry | FLUENT | 1 | February 15, 2007 10:29 |
Volume Fraction | cheong | FLUENT | 1 | November 28, 2001 04:06 |
