Two fluids in two different volumes
Hi everyone
Iīm simulating a solar receptor where i need to remove the heat from the receptor with the help of a heat exchanger, in the receptor domain i use air as a fluid, but in the heat exchanger domain i need to use water to remove the heat and then quantify it, but the issue is that i canīt work with these two different fluids (and properties) at the same time, how can i do that? :confused: Thanks in advance. |
