Squeeze Flow
Old   October 17, 2012, 16:46
Default Squeeze Flow
Michael Anderson
mjaisit is on a distinguished road
I am trying to model a 2d version of squeeze flow between two plates. I tried to make it as simple as possible since I am new to fluent. I made a simple 5x.5 meter rectangle for the geometry in the xy axis and defined a finer mesh. For the boundary conditions I specified the top as a moving boundary condition moving in the -y direction at .1 m/s, my left and right boundary conditions as outflows, and the bottom as a stationary wall. I am obviously doing something wrong because when i create an animation of the contours of x velocity is does not change with time. If anyone has any suggestions it would be greatly appreciated.
mjaisit is offline   Reply With Quote
Old   October 18, 2012, 07:55
Marion
Marion is on a distinguished road
Well it could be an issue with the time step...
Is your moving wall actually moving when you play the animation?
How much is the constant X velocity given on the contours?
Marion.
Marion is offline   Reply With Quote
Old   October 18, 2012, 16:16
Michael Anderson
I have the time step set to .1 sec with the total run time as the time taken for the moving wall to reach the stationary wall. Do I need a smaller time step? The wall boundary condition is not moving in the animation. I wasnt sure if the animation would show it or if it would just show the change in the contours of the properties that were being tracked. I should have specified what i was talking about with the x velocity contours, there are actually no contours. It is showing the entire rectangle as the same velocity and does not change with time. I am really confused because pressure contour animation plot looks realistic.
Old   October 19, 2012, 05:09
Marion
You should see the moving wall moving with time! if it's not, then it is normal that the velocity doesn't change.
How come the wall doesnt move? have you checked the mesh motion with the "preview mesh motion" feature in the MDM panel?
Marion.
Old   October 24, 2012, 16:34
Michael Anderson
I have contacted customer support also for help and was told that I need to use define_cg_motion. So I take it that specifying the boundary condition as a moving wall is not enough to acutally make it move. I am going to consult the user manual for writing a udf for this.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
