Postprocessing issue with dynamic mesh?
Old   October 29, 2012, 12:38
Default Postprocessing issue with dynamic mesh?
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi all!
I was trying to simulate a dynamic mesh problem:
a parallelepiped which moves inside another parallelepiped, in z direction with an armonic motion (I used the DEFINE_CG_MOTION macro).
My domain is splitted into 3 parts: top, center (which includes the small parallelepiped) and bottom; these parts are connect with non conformal interfaces
I set layering in dynamic mesh options, specified the top and bottom as stationary and center as rigid body.
When plotting z velocity contour, for example, both in fluent built in postprocessing and CFD-POST, I obtain strange values (also vectors) at wall in the central region;
if I plot contour in tecplot it seems all is ok...
See attached pictures..
What do you think?
Thank you all
Daniele
ghost82 is offline   Reply With Quote
Old   November 2, 2012, 10:06
ghost82's Avatar
Rick
Found on a presentation:
If you turn a fluid zone into a dynamic zone, you should also turn the associated moving walls into dynamic zones otherwise the incorrect wall boundary conditions will be applied, and you will get unphysical velocities adjacent to the wall.
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
potentialFreeSurfaceFoam with Dynamic Mesh GuilhermeMP OpenFOAM Programming & Development 1 October 6, 2013 03:05
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
