-   FLUENT (
-   -   Acoustic Simulation in Fluent (Pre-defined sound source) (
bassam693 October 30, 2012 01:42
As we know, in Fluent (with acoustic model turned on and by using the FWH solver) we can set surfaces as sound sources in order to calculate acoustic data (ex: dpdt RMS) at them, and to calculate sound pressure level at some predefined receivers. In addition to that, I need to include some predefined sound source; for example, i need to specify a surface that is already emitting sound (constant sound pressure level in dB) even before taking into consideration the simulation that will go on.
More specifically my problem in the following:
I'm running a simulation around an aircraft and i'm interested in the acoustic field at its airframe and the SPL at some receivers. However, in addition, I would like to have the engine emitting sound with constant SPL (dB) during the whole simulation. The point of the simulation is to see how the engine sound affects the acoustic field that is generated from the flow itself. Is that possible ??? thank you in advance.
kabilan January 2, 2016 08:06
fluent jet acoustics
please help me for acoustic modelling in fluent.
i am doing jet acoustics for that i made modelling and meshing in gambit ie jet
from pipe.
in fluent i am using FWH for acoustic in that to define source what should i have to give but it show wall but ii need jet as source.
please help out this problem.
thank you
