Boosting CPU usage
Old   November 2, 2012, 09:58
Exclamation Boosting CPU usage
earlybird is on a distinguished road
I use ANSYS/Fluent v.13 to do a 3-D simulation. I can use Parallel (local machine) and my CPU is a i7 2600 3.4 CHz with 16 GB of RAM.
when I chose parallel option in Fluent Launcher and set to 4 cores (I guess it is the maximum that I can go with since i7 2600 has 4 cores) then I see that during the simulation the maximum CPU usage does not pass 50%!!
does anybody know how to boos the CPU usage to reach to 100% usage?
Many thanks
earlybird is offline   Reply With Quote
Old   November 2, 2012, 10:25
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Don't worry, everything is fine! Your CPU supports something called "hyper threading", where every physical core fakes a second one to optimize cpu usage. Thus, windows thinks you have 8 cores. When you use 4 of them, Windows shows a CPU usage of 50%.
http://en.wikipedia.org/wiki/Hyper-threading
RodriguezFatz is offline   Reply With Quote
Old   November 2, 2012, 10:32
thank you for your rapid response ,
by this, it means that the CPU is actually working 100% not 50%, and yes you are write because I see 8 windows instead of 4 in CPU performance window!
FloWorks and CPU usage? cvp_dk FloEFD, FloWorks & FloTHERM 6 June 20, 2011 08:57
How to max the CPU usage? Christoph_84 Hardware 2 June 8, 2011 15:45
50% CPU usage AEsco48 CFX 9 March 13, 2008 16:44
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 05:26
