-   -   Divergence in amg solver while using second order scheme (http://www.cfd-online.com/Forums/fluent/108850-divergence-amg-solver-while-using-second-order-scheme.html)
raj November 2, 2012 13:51
Hi all
Iam doing a transient combustion analysis with partially premixed model and compressible case. I am using k-e realisable turbulence model. While running the case with all methods set to first order i got good convergence of results. However when i changed to second order schemes i get the amg solver divergence . Kindly suggest me what could be the problem
vicarious November 2, 2012 14:34
Second order Schemes got less relaxation to the high gradients because the adjacent cells involved are more( j+2,J-2), thus the high gradients of parameters could result in a bad behavior. Try to decrease your RFs and check the Green-Gause node based in solver panel.
Regards.
raj November 3, 2012 00:39
Hi Thanks for the reply
I have reduced the relaxation factors and the solver is running. But i would like to ask one thing whether by reducinf the RF's does it alter the final results?
cfd seeker November 3, 2012 02:10
No your final solution will remain unaltered however your convergence time will be more with the reduced values of RF's
