how to control the number of particles ejected using DPM?
Old   November 5, 2012, 18:59
Default how to control the number of particles ejected using DPM?
yahya
yahya is on a distinguished road
I'm trying to eject droplet particles using DPM technique, however, I couldn't find the way to determine the number of particles to be ejected?
Can anyone help me regarding this matter? and If I can't determine the number of particles what else I can control ?
yahya is offline   Reply With Quote
Old   November 9, 2012, 04:21
Mat
Mat_fr is on a distinguished road
In the Discrete Phase Model window, you go to "injections", and you create a new one.
In the Set Injection properties window, you have the following box : "Number or particle streams", which is fixing the number of p. to inject for your simulation.
Be careful to the difference between steady and unsteady tracking !
Best,
Mat
Mat_fr is offline   Reply With Quote
Old   November 21, 2012, 11:31
Mina
kingpots is on a distinguished road
@ Mat_ : do You know how the injected mass flow rate is determined during the injection , as it is a bit confusing for the case of the unsteady tracking , we do have Particle time step size , number of steps , and the start stop injection time
kingpots is offline   Reply With Quote
Old   October 13, 2013, 13:10
tien
tienmanhnguyen is on a distinguished road
dear Yahya, do you know how to enable the "droplet" in "set injection properties" tab, since the "droplet" is not available in my case. thanks a lot.
tienmanhnguyen is offline   Reply With Quote
Old   October 13, 2013, 13:40
yahya
Well if you want you can communicate with me through facebook or skype?
Because i dont understand ur question clearly
Its ok for you?
Old   October 13, 2013, 19:56
tien
Dear Yahya, thank you so much for concerning my problem. however I think I just need to ask you whether I have to turn on "species transport model" to be enable to turn on "droplet" option in "set injection properties" tab. since I did it and it worked. thanks in advance.
Old   October 13, 2013, 20:06
yahya
I think if u just enabled the DPM model it will directly enabled the droplet
The things that you need to do is to define primary phase then the seconadry phases (droplets) then after defining the droplets materials in the set injections you should see the droplet with the type of material you wish to use (any of the secondary phases) tell me your progress and im ready to help you regarding the DPM, since im done with this issue
Old   October 13, 2013, 20:13
yahya
Well i dont think you need to use this species model to enable them, i dont remember that i used it
How to find the number of particles trapped prashant FLUENT 5 January 3, 2020 03:33
trying to simulate two-phase jet flow with particles in surface injection ajkratos FLUENT 5 March 3, 2015 21:33
[snappyHexMesh] SnappyHexMesh AddLayer Control rdrr84 OpenFOAM Meshing & Mesh Conversion 28 May 30, 2014 05:32
Pls help: unsteady, DPM, track, particles, number fivep Main CFD Forum 2 March 7, 2009 00:35
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
