contact angle
Like Tree1Likes
  • 1 Post By yan
Old   June 29, 2005, 15:26
Default contact angle
yan
Hi
I am using the Flunt VOF model to simulate the capillary-driven flow. In my simulation, I specify the contact angle as a given value, but when I draw the two-phase interface by using vof=0.5 iso-surface, I found that the contact angle at the wall is not the value I input. I checked the user guide, but I am still not clear about how Fluent handle the contact angle. Can anybody explain it to me, or give me some suggestions about correct ways to check the contact angle value?
Thanks.
Yan
shiraz_man67 likes this.
Old   June 30, 2005, 04:09
Default Re: contact angle
edi ghirardi
Are you using Geo-reconstruct scheme? the mesh is quad (hexa)? How much is the difference between the angle you found and the one expected?
Old   June 30, 2005, 11:07
yan
I tried Geo-reconstruct and the explicit schemes. My mesh is quad. If I use the cell value for the vof=0.5 surface and then calculate the angle, the differences are almost 7 deg. I am not sure my method to calculate the angle is corrct or not.
Thank you for your reply.
Yan
Old   August 29, 2011, 19:55
Season
wxc870522 is on a distinguished road
Hi! Did you figure it out? I encountered the same problem....
wxc870522 is offline   Reply With Quote
Old   November 6, 2012, 04:22
Default Same problem!
shiraz_man67 is on a distinguished road
I have same problem too as I input an angle lower than 20 degree it shows angle more than 150 degree! and my hydrophilic surface act as super hydrophobic one as the angle more than 20 the difference is lower I don't realy know what is the problem
shiraz_man67 is offline   Reply With Quote
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
InterFoam contact angle JoaoMiranda OpenFOAM Running, Solving & CFD 7 October 20, 2016 06:27
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
