June 16, 2015, 22:06 |
Conjugate Heat Transfer Analysis Problem
RJC
Rep Power: 10 |
I am doing a transient conjugate heat transfer analysis between a solid zone and a fluid zone in 2 steps in Ansys Fluent. In step 1, the fluid zone has fluid 1 with high velocity (forced convection). However, in step 2, I have stationary fluid 2 (natural convection) in the fluid cell zone.
I changed the material of the fluid cell zone in step 2 and also changed the BC as required. The simulation runs okay, but the results are not right. For some reason the heat transfer in step 2 is slowed down significantly. Even the temperature change in the solid zone is very low which is not acceptable. All on a sudden, the system is heading towards steady state, but that is not the actual case. Any suggestion? |
June 16, 2015, 23:39 |
RJC
Rep Power: 10 |
The results of the first step is okay. The heat transfer as well as flow velocity looks okay. The problem is with the second step only.
cell zone, conjugate heat transfer |
Problem with conjugate heat transfer in Fluent | JianT88 | FLUENT | 0 | March 16, 2015 08:17 |
problem in conjugate heat transfer | reza67 | FLUENT | 2 | December 2, 2014 03:16 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Hypersonic conjugate heat transfer problem | carnage2121 | FLUENT | 0 | June 4, 2011 18:08 |
conjugate heat transfer problem | Andreas | CFX | 1 | February 5, 2002 18:22 |
