Uplus vs Yplus
1 Attachment(s)
Hi all,
I want represent Uplus as a function of Yplus in Fluent. I simulated the simple case of water flow in a pipe. But, the representation of Uplus as a function of Yplus doesn't agree with literature. What I'm doing wrong? Regards |
I defined a Custom Field Function for Uplus and another for Yplus... Yplus I compared with the values of Ystar from Fluent and it is OK... For Uplus I used the expression: Uplus=|V|/(0.09^0.25*turb-kinetic-energy^0.5). As Yplus agree with the Ystar from fluent, the Uplus probably is not being well calculated, but I'm not sure about that.
I can calculate Yplus and Uplus for all domain or just for the points near the wall? I'm confused :( |
hi bud,
a couple of things: 1) remember y+ is a log quantity, so make sure you are plotting on the correct axes ... 2) your first point looks like its at y+ = 5, so to see the laminar sub layer (if that is what you want in addition to the log region, you need to be calculating from Y+ = 1 at least ! cheers Jonathan edit: sorry, didnt see your last question - y+ / y* is only valid for wall adjacent cells ... |
y+ is the normalized distance to the wall. That's why it can be calculated for every location in the domain. For some reason it is commonly accepted to call the y+ value of the wall adjacent cells just "y+".
hi Lucky / Rod,
well, yes technically i suppose you guys might be right - i guess it depends how you define distance y. for example, in most CFD contexts, y is defined as the distance between the wall and the centroid / node of the wall adjacent cell, and you will get zero for interior cells. but in a contiuum context if you define y as a distance from the wall to some interior point, yplus is simply a non-dimensional distance from a surface. from the tone of the post, i thought it would easier to keep it simple, but i take your guys point ... cheers jonathan |
I'm using the stanrd wall function in the k-e turbulence model...
1 Attachment(s)
I changed the expression that I was used to calculate u+ and y+... u+=|V|/((tauW/rho)^(1/2)) in which tauW is the value of wall shear stress and now the representation is goodhttp://www.cfd-online.com/Forums/dat...AooooAKKKKAP/Z
