visualising time derivatives
Old   November 8, 2012, 23:14
Default visualising time derivatives
Dorit is on a distinguished road
Hi everyone,
I hope that someone has a simple suggestions for what I'm trying to do. I basically want to plot the time derivative of for instance the x velocity in an unsteady simulation. I then want to export the x acceleration contour every N time steps.
Solution 1) Somehow create a new variable that calculates the x acceleration at every time step and then use the automatic export feature. I don't think this can be done using the Custom Field Function Calculator. Any ideas?
Solution 2) Write a UDF that calculates the x acceleration and writes it to an output file. I've found out about the C_U(c,t) and C_U_M1(c,t) functions which give me the x velocity from the current and previous time step, so it's easy to get the acceleration. But I'm having trouble with using thread_loop_c and begin_c_loop_all macros to access all cells/nodes on the surface of interested. Aside from that I wouldn't know how to save it in a format which allows the data to be easily visualised in Tecplot again.
Thanks for any thoughts/comments.
Dorit
Dorit is offline   Reply With Quote
acceleration, contour, post procesing, time derivative, udf exporting variable
InterFoam negative alpha karasa03 OpenFOAM 7 December 12, 2013 03:41
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
