Home > Forums > FLUENT
question about importing a SAT file
Old   November 9, 2012, 21:31
Default question about importing a SAT file
mona rezq
arch mona is on a distinguished road
hi every body ,
I am architect, new in cfd work and I want to simulate natural ventilation in a building but I have a problem in converting dwg (3d) & revite files to ansys fluent , I exported the file into sat format and Imported it into ansys fluent but the program read walls as mesh so how can I convert the file correctly ?
Thank u all
arch mona is offline   Reply With Quote
Old   November 10, 2012, 07:03
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
where did u make the mesh?
Far is offline   Reply With Quote
Old   November 10, 2012, 19:22
Question
mona rezq
thank you for reply
I am asking about how to make the mesh as I want to study natural ventilation throw a building .
Old   November 10, 2012, 19:26
Far
Sijal
Use ansys meshing or ICEM CFD to make the mesh
Old   November 10, 2012, 19:28
mona rezq
I exported the file into sat format only and I dont know wat is the next step ?
Old   November 10, 2012, 19:48
mona rezq
so the mesh must be drawn , wat about walls the program traet with them as mesh and wat about furniture I should remove it from mesh ?
sorry for questions but I need to understand and thank you
Old   November 12, 2012, 09:27
Jasdeep
jasdeep2006singh is on a distinguished road
You need to make control volume, would be about 15 times the dimension horizontally and 5 times up and down. then while meshing, or if you can do in 3d modelling software itself, subtract (boolean operation) the building from the control volume. You will end up with a big box with building shaped hole inside. then mesh that box, define inlet, outlet and walls.
Hope this helps !
jasdeep2006singh is offline   Reply With Quote
Old   November 12, 2012, 13:01
Default many thanks
mona rezq
I will try that and thank you so much
Old   November 13, 2012, 02:10
Jasdeep
Also, since in your case it is a building, there will be no dimension below (obviously), the building will be on one wall. i keep space everywhere in wing study and stuff like that...
Thread Tools
Trackbacks are On
problem on installing swak4Foam navid2 OpenFOAM Installation 2 May 30, 2012 04:32
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
