-   -   how to use mixture model for nanofluids (http://www.cfd-online.com/Forums/fluent/109139-how-use-mixture-model-nanofluids.html)
CANDY November 10, 2012 04:15
Dear all,
I am trying to analyze nanofluids numerically using mixture model.
In that secondary phase is not giving the option of using the solid as the material. How to overcome this problem.
thanks in advance.
msaeedsadeghi November 12, 2012 07:47
haha :)
Nanofluid does not mean to import solid nano particles. Nanofluid works just with fluid properties. First you should calculate fluid's new properties (because of nano particles effect on fluid properties) on a paper. Then input the new properties in the material properties.
CANDY November 14, 2012 00:24
i want to study the effect of particle size, hence i need to use the mixture model.
eslamian January 17, 2013 17:45
Need to use discrete phase model to be able to add the thermophoresis effect.
I am trying to do the same thing, but dont know how to introduce the nanoparticles as a discrete phase. Initially nanoparticles need to be dispersed within the base fluid. Any idea how to do it in FLUENT?
msaeedsadeghi January 19, 2013 00:35
Compare nanoparticle equations with ANSYS FLUENT equations, then add every equations needed by UDFs. I am sure fluent can solve it.
Goutam October 9, 2013 06:42
Originally Posted by CANDY (Post 391363)
Dear all,
thanks in advance.
Hallow, CANDY
Did you able to solve the problem? I am trying to do the same thing, but still didn't able to manage this? If you solved this problem, could you shear your .cas file, how to setup mixture model in Fluent for nanofluid?
Thanks in advance
Goutam Saha
Email: g.saha.1@research.gla.ac.uk
Goutam November 30, 2013 07:54
Dpm
Dear All,
Could you tell me how to setup discrete phase model for nanofluid in Fluent?
thakuramit682 December 19, 2015 09:00
Dear all,
thanks in advance.
HI CANDY, have you solved your nanofluid analysing using mixture model? I have the same problem. can you help me with this?
my email id is thakuramit682@gmail.com
thanks in advance
ghofrane February 23, 2016 21:20
DPM nanofluids
hi all please i try to use DPM for steady the motion of nanopparticles but i can t give the proporeties of the nanoparticles, there is a list for materials and i dont found my case please help me and thank you very much
rajann_786 March 23, 2016 06:54
Please refer this
http://www.sciencedirect.com/science/article/pii/S1290072912003420
