November 16, 2012, 15:53 |
Problem in Journal File
Rep Power: 13 |
Can anybody explain what is the meaning of something like ,,,,, n n n n in a boundary condition? I am writing a journal file, I would like to set a property for a mixture. How can I have access to a property of a mixture using a journal file? Thanks guys, Negin |
November 16, 2012, 19:29 |
Lucky
Rep Power: 65 |
If you have it, check out the fluent help file and look at the section on TUI (text user input).
Whenever Fluent is prompting for an input (in both GUI and TUI) pressing comma (,) or enter will accept the default value for the prompt. n is short for no. y is short for yes. Hence, when you try to change a wall boundary condition, Fluent will ask you (in some specific order) all the boundary conditions and you must enter them. In your case: ,,,,, n n n n is equivalent to pressing enter 5 times and then answering no 4 times to whatever the prompts are. If you are writing a journal file then you need to know what order and how many prompts are going to appear so that you can anticipate your responses that you will provide. |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
