Home > Forums > FLUENT
Which Kind of Multiphase model?
Like Tree2Likes
  • 1 Post By ghost82
  • 1 Post By ghost82
Old   November 12, 2012, 12:27
Default Which Kind of Multiphase model?
fshak92 is on a distinguished road
I'd like to model a "Fluid line" lied on a "solid plate".
An "air block" has been created to surround the "fluid line".
As you can see in the picture, the "fluid line" has been created like a solid block;but after running it should be deformed like a real fluid.
Therefore, i'm not sure which kind of multiphase model should be used for having the deformation of the "fluid line" IN the "air" and ON the "solid plate" after running.
(Or even if i should not use the multiphase mode...)
Big block (A) = Air
The thin block line (B) = a high viscous fluid
The violet block (C) = a solid plate
Thank you in advance.
fshak92 is offline   Reply With Quote
Old   November 13, 2012, 07:02
I guess Free Surface-VOF model should be used but i haven't been able to simulate yet.
e.g in cell zone conditions, when i set The "fluidline" as Phase2 , then the "AirBlock" is set to phase2 automatically and i cannot set 2 different phases to the different blocks(air and FluidLine)
I also doubt about having the AirBlock or remove it... .
Does anybody have any suggestion about the settings can be used?
Old   November 13, 2012, 09:57
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
why do you want to create the solid domain?; you have to create the high viscous fluid domain and the air domain, then set as wall boundary conditions the surfaces of the solid plate
It seems also you can simulate it as 2D, instead of full 3d.
The VOF model seems ok to me; after initializing you have to patch the domain of the secondary phase, so you will have air domain with 100% air and high viscous fluid domain with 100% viscous fluid.
Then you can start your unsteady simulation.
Hope that helps
Daniele
fshak92 likes this.
ghost82 is offline   Reply With Quote
Old   November 14, 2012, 07:09
Originally Posted by ghost82 View Post
Hope that helps
Daniele
Thank you for the reply.
I activate the VOF model(with default options).
Then i go to "cell zone conditions", when i set The "fluidline" as Phase2 , then the "AirBlock" is set to phase2 automatically(and vice versa) and i cannot set 2 different phases to the different blocks(air and FluidLine).
Instead, you mean setting the "mixture" for both blocks,then patching my second phase(fluid) to my first phase(air) with the volume fraction of 1? right?(i dont get any message when i patch fluid zone to the air zone)
Also i have some walls for the air block and the fluild block,Should i leave them with default values?
e.g in momentum field,all of them are set to "stationary wall". they shouldn't be changed to "moving wall" ... ?
Old   November 15, 2012, 09:37
ghost82's Avatar
Daniele
I attached a picture to clarify my above comments: you should have 2 continuum zones (fluid 1 and fluid 2) and 2 boundary conditions (wall for the bottom solid plate and for example pressure outlet (?) for the other 3 edges) to define the volume of air.
Initialize your problem, then you have to patch the fluid 2 zone with your high viscous fluid.
Once you have patched the zone, plot the contour of phase-1 volume fraction to verify you have patched the zone.
As you can see I would model it in 2d; remember to specify reference values in your problem.
Daniele
fshak92 likes this.
Old   December 3, 2012, 08:02
Thank you for your helpful suggestions.
I have some problems with the convergence of my simulation.
The courant number is very high and reversed flow at pressure outlet is occurred in my simulation.
I think coarsening the mesh (For decreasing courant number) decrease the accuracy of my simulation.and reducing the time step, can increase my computation time a lot.(i tested until the time step of 0.001s and still it had problem )
(By using the time step of 0.0001, i didnt get the error for courant number. But still there is reversed flow problem )
According to the mesh and details of the below pictures, what would you suggest for solving my problem?(high Courant number and reversed flow)
I also used a gauge pressure of 1000 pa and 3 kinds of backflow option, but still the same number of reversed flow faces can be seen.
Moreover,using the boundary conditions (outflow , outlet-vent and wall ) for the airOutlet , didn't give me a convergent solution.
First picture show the phase contour after simulation divergence for time step of 0.001.
Second one for the time step of 0.0001.
The contours for pressure and velocity are also shown in third and fourth pictures.
(Also,I dont know how the maximum velocity of 5 m/s has been generated in the air domain,because i dont have any initial velocity)
Old   December 5, 2012, 21:08
Smile heat exchange
zhangmin
Kaixin is on a distinguished road
Hello,all:
I want to know how to set the value of carbon dioxide scattering coefficient in the fluent button,who knows?thank you.
Kaixin is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 16:01
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 13:05
multiphase mixing Problem with MRF model in MixSim Srinivas FLUENT 0 October 17, 2005 06:35
multiphase model Sumeet FLUENT 2 August 31, 2005 08:26
