how to make moving surface(flutter surface) ?
Old   November 16, 2012, 10:04
Exclamation how to make moving surface(flutter surface) ?
musab
bluAero is on a distinguished road
I am aeronautical engineering student, and I have graduate project named
Flexible wing .
And is a flexible wing featuring movement of the upper surface flutter .. Means the upper surface moves up and down (the top surface shown in green in the below pic), and this process improvement aerodynamics properties of the wing ...
Important:
Now I want a way in fluent program so make this a moving surface in fluent and I could take readings required ..
I tried through the dynamic mesh
But I did not make it -_-
i hope one of you will help me and explain to me how moving the upper surface .
bluAero is offline   Reply With Quote
Old   November 18, 2012, 12:29
cfd seeker is on a distinguished road
You can do it with the help of UDF but for that you must know the equation for the movement you want to model
cfd seeker is offline   Reply With Quote
Old   November 18, 2012, 14:01
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
this is a very interesting. sorry that i can't help that much. CFD-seeker can you enlighten us on how to do that if you have the equation of movement. may be with your own equation. how did you achieve that ? thank you very much
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 2 April 20, 2023 08:28
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
moving free surface with VOF alilouu FLUENT 2 September 29, 2011 16:19
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
Moving Surface Pedro Romero FLUENT 0 March 30, 2007 12:09
