Home > Forums > FLUENT
Fluid Structure Intercation
Old   November 17, 2012, 18:12
Default Fluid Structure Intercation
Markat is on a distinguished road
I would like to ask, if it is possible to build a transient FSI Model in ANSYS Fluent. Should I use UDF to make the coupling?
Markat is offline   Reply With Quote
Old   November 18, 2012, 06:38
At the time I am building a 1 way FSI steady state model. Everything can be done in ANSYS Workbench... No need of UDF... But for the transient one?
Old   January 3, 2013, 17:53
stumpy is on a distinguished road
I assume you are connecting to Mechanical. One option is to use the External Data component. Follow the doc for "Importing Multiple Data Sets" in the Workbench book
// User's Guide // Systems // Component Systems // External Data // Importing Multiple Data Sets
The other option is to ask ANSYS for the ACT (Application Customization Toolkit) files for 1-way transient FSI.
stumpy is offline   Reply With Quote
Old   January 14, 2014, 06:48
Andrew Hallow
AndyH is on a distinguished road
This depends entirely on what information you need to have in the model. In my experience you should go for a UDF based implementation if:
Either:
1) You also need to include other custom modeling beyond the standard capabilities of ANSYS. For example, take a look at this snow deposition/erosion model implemented on Fluent.
or:
2) The structural model can be relatively simple, so that you don't need a full-featured FEM solver to do the job. For example, I have implemented a transient model for an opening hatch using a simple spring-dashpot model (3 parameters) as a UDF. I could handle it with simple Euler-type timestepping, i.e. without interfacing a FEM solver.
Hope this helps.
AndyH is offline   Reply With Quote
Thread Tools
Trackbacks are On
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 09:16
Fluid Structure Interaction using icoFsiFoam Problems lr103476 OpenFOAM Running, Solving & CFD 79 August 7, 2014 09:30
Fluid structure interaction. Haree FLUENT 2 August 7, 2010 02:56
Fluid structure interaction in Fluent Hari Prasad FLUENT 2 July 16, 2010 03:17
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
