Uplus vs Yplus Non-Newtonian Fluids
1 Attachment(s)
Hi all,
I want simulate a turbulent pipe flow of a non-Newtonian fluid... I'm looking for the representation of U+ as a function of y+, because I'm going change the log wall law taking into account a reference in the literature. The non-newtonian behavior was translated by a power law (viscosity as a function of shear rate) that is available in Fluent for turbulent flow... In the figure, the green line corresponds to the standard log-law considering the viscosity constant. The U+ presents a strange behavior... Someone knows why I obtained this behavior, some references about the non-newtonian fluids and turbulence in CFD or how the non-newtonian behavior is implemented in the k-e turbulence model? Thank you |
1 Attachment(s)
I've calculatd y+ with density and viscosity in each node, but I found a paper where the authors considered the mean wall viscosity instead of Newtonian viscosity. If I consider the mean wall viscosity the profiles seem be OK... what strategy is correct?
Someone knows if in the dimensionless distance (Attached Expression) http://www.cfd-online.com/Forums/dat...AAAElFTkSuQmCC http://www.cfd-online.com/Forums/dat...AAAElFTkSuQmCC the density and the viscosity when the fluid is non-newtonian is evaluated in each node or can be equal to mean wall viscosity? |
