conjugate heat transfer(AIRFOIL)
Old   November 24, 2012, 01:17
Default conjugate heat transfer(AIRFOIL)
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
i am trying to simulate conjugate heat transfer for an 2D airfoil(inside slat). i am using k-epsilon turbulence model, incompressible-ideal-gas as material. my objectives are to achieve temperature raise inside the slat, and relevant velocity at the outlet of airfoil. the boundary conditions that i am using are
1) Velocity inlet(for external aerodynamics), 263K.
2) Mass flow rate(internal inlet, inside slat) 373K.
there is proper flow inside the slat, but there is no temperature rise as desired.
please help me out, is there anything wrong with my boundary conditions?
Bharatt is offline   Reply With Quote
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 06:33
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Conjugate heat transfer kiteguru CFX 2 January 9, 2012 15:57
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Conjugate heat transfer with periodic boundaries Suresh FLUENT 0 February 23, 2009 09:51
