-   -   How to define a 2-D surface in a 3-D geometry? (http://www.cfd-online.com/Forums/fluent/109565-how-define-2-d-surface-3-d-geometry.html)
amir2920 November 20, 2012 19:32
I am Using Ansys 14.0. I want to define a surface (a circle) on my 3-d geometry. But the design modeler software needs thickness and does not creates a surface in a 3D geometry. I need to determine this circle on a part of my geometry, because I need to calculate something specifically for this circle are in FLUENT. So I need to define a name for it in (named selection) then I will be able to select that in FLUENT and calculate for that area. What should I do?
Please help me with this. Thank you.
Marion November 21, 2012 04:46
The thing is to have nodes on this geometry in order to define it within Fluent. so it has to be part of your geometry definition: I think you need to split your geometry where you want to put the disc. Then split that face with a disc. And define the disc as "interior".
However, if it's only post processing, you may be able to do this in CFD post directly.
Marion.
