Cleanup file editing
Old   November 21, 2012, 22:26
Unhappy Cleanup file editing
Dave Christopher
David Christopher is on a distinguished road
I am running Fluent with multiple processors. Sometimes when fluent crashes, I need to kill all the processes. Fluent has generated a "cleanup-fluent-localhost.###" file that I can run, but the file has an error in it that I have to fix every time.
most of the lines have:
if [ $LOCALHOST = local.host.localdomain ]; ...
but one line is missing the ".localdomain" part in two places.
If I edit the file and add that part, the file runs fine.
How can change the Fluent startup to correctly create the file in the first place?
David Christopher is offline   Reply With Quote
edit cleanup error
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
