Discrete Ordinate Fluent Radiation Intensity/Heat Flux
Hi, I've been a long time lurker/searcher on these forums but I can't find a straight answer anywhere to my question (which I think should be simple...):
How do I see/get-the-data-into-a-spreadsheet the radiation heat flux distribution and radiation intensity distribution (for each direction) in my 2D plane-parallel discrete ordinates problem? I'm working on a project for school and this is the first time I've ever used ANSYS, but I'm fairly certain I have set up and solved the discrete ordinates method correctly; I just can't get the results I need... I can plot and retrieve incident radiation, G, in a spreadsheet, but I need the intensity and heat flux distributions. I have 2 plane-parallel black walls, separated by a 1cm distance, with that space filled with a participating solid media. I made the walls 10cm long, and then defined a periodic boundary condition on the sides. Thanks for any help/advice, if any more info is needed, let me know! |
Hi kozzney,
