Discrete Ordinate Fluent Radiation Intensity/Heat Flux
Old   November 26, 2012, 17:17
Default Discrete Ordinate Fluent Radiation Intensity/Heat Flux
kozzney is on a distinguished road
Hi, I've been a long time lurker/searcher on these forums but I can't find a straight answer anywhere to my question (which I think should be simple...):
How do I see/get-the-data-into-a-spreadsheet the radiation heat flux distribution and radiation intensity distribution (for each direction) in my 2D plane-parallel discrete ordinates problem?
I'm working on a project for school and this is the first time I've ever used ANSYS, but I'm fairly certain I have set up and solved the discrete ordinates method correctly; I just can't get the results I need... I can plot and retrieve incident radiation, G, in a spreadsheet, but I need the intensity and heat flux distributions.
I have 2 plane-parallel black walls, separated by a 1cm distance, with that space filled with a participating solid media. I made the walls 10cm long, and then defined a periodic boundary condition on the sides.
Thanks for any help/advice, if any more info is needed, let me know!
kozzney is offline   Reply With Quote
Old   December 4, 2012, 05:30
Rami Ben-Zvi
Rami is on a distinguished road
Hi kozzney,
  1. In order to get the surface heat flux of certain boundaries, you should plot them using the XY Plot menu, selecting Wall fluxes... for the Y axis Function. Define the specific function below (e.g., Radiation Heat Flux or otherwise), choose the X Axis Function and the desired BCs (note that for the Curve Length option for the x axis, you can choose a single BC at a time) and check the Write to File option. Click Write... and define the file name. You will get a text file that is readily imported to a spreadsheet.
  2. AFAIK, you have no direct access to the intensity field. Maybe this can be done by UDFs. Check the manuals.
  3. I referred above to the DO model. It may be different with other radiation models (S2S, DTRM,...).
Rami is offline   Reply With Quote
ansys, discrete ordinates method, dom, fluent, heat flux
Macros for discrete ordinate, non gray model yashmash FLUENT 1 March 19, 2012 03:13
Radiation model-Discreate ordinate Method MANOJKUMAR FLUENT 0 October 20, 2005 02:15
Radiation flux to the wall surface Jason Phoenics 1 May 26, 2004 02:13
transient heat flux in FLUENT Jayanti Sinha Main CFD Forum 0 November 6, 1999 19:43
Fluent incident radiation problem Michael Schwarz Main CFD Forum 0 October 21, 1999 06:56
