November 28, 2012, 04:19 |
#21 | |
Smaras
Rep Power: 13 |
Now if i am using directly 1e-3 from the start. The courant no. is increasing surpassing 250. So what to do now? |
November 28, 2012, 04:31 |
#22 |
Philipp
Rep Power: 26 |
Alright! Now, in your residual picture it looks like the first 2000 iterations did not converge at all, is that right? How many iterations per timestep did you set as maximum, 25? That means that the first 80 time steps did not converge? Maybe the loss of mass happens right there. Every single timestep of your simulation should converge in a satisfactory manner, otherwise you can not expect mass conservation.
I would try to increase the maximum number of iterations and see if you get convergece for the first timesteps.
The skeleton ran out of shampoo in the shower. Last edited by RodriguezFatz; December 3, 2012 at 03:37. |
December 3, 2012, 03:37 |
#23 |
Philipp
Rep Power: 26 |
Did it work out Smaras?
The skeleton ran out of shampoo in the shower. |
December 3, 2012, 03:53 |
#24 | |
Smaras
Rep Power: 13 |
i tried to refine the mesh (adopt) in the regions of inlet and the interaction of two phases and used 10 iterations per step. Using 1e-5 as step size and 10000 steps. Got convergence after 3000 iterations i.e. 300 ts. And then onward every step got convergence. I don't know why there is mass loss, may be because of viscous heating even though i have not selected that option or either it was something else. But in this run i have got relatively less mass loss and was getting almost similar penetration as in the research papers. now i want to use K-w SST model what would you suggest??? |
December 3, 2012, 03:59 |
#25 |
Philipp
Rep Power: 26 |
Hold on. You really need convergence every single timestep. Otherwise you can not take things such as mass conservation into account: What, if during your first 100 non-converged time steps something unphysical happens? Your equations are not converged and it can easily happen, that you lose some mass or whatever. You need to do as many iterations as it takes to get a converged solution right from the start, for time step number one, number two...
December 3, 2012, 04:03 |
#26 | |
Smaras
Rep Power: 13 |
December 3, 2012, 04:17 |
#27 | |
Smaras
Rep Power: 13 |
Now running both simulations and will take around a day or so to complete. Then see what is the penetration. And hope now there would be no mass loss. Thanks once again Rodriguez fro help. Regards, Smaras |
December 4, 2012, 02:41 |
#28 |
Smaras
Rep Power: 13 |
Thanks Rodriguez,
For the help, the problem lies in the pressure residual monitor. Even though it wasn't not changing too much but it wasn't giving converging.....i have also change it to 0.01 and now getting converging at every iteration. Further no mass loss and the penetration is also kept the step size 1e-5 and iteration per step 20. Getting converge solution. Better results in both models. Thanks for the help, learnt a lot. Regards, Smaras |
December 4, 2012, 09:09 |
#29 |
Philipp
Rep Power: 26 |
Just one more comment:
By "change it to 0.01" i guess you mean that you increased the residual convergence criterion to 0.01 ? You should better try to increase the max. number of iterations (and lower the residual) than relaxing the threshold of "good" and "bad" convergence.
December 4, 2012, 09:37 |
#30 | |
Smaras
Rep Power: 13 |
December 14, 2012, 04:29 |
#31 | |
Smaras
Rep Power: 13 |
now working on 3D. Need some help, do you have some idea where to find good resource on meshing techniques in ICEM. And mesh refinement for 3D. Regards. |
December 14, 2012, 04:44 |
#32 |
Philipp
Rep Power: 26 |
Watch the youtube tutorial by Simon (PSYMN in this forum). Search for "ICEM CFD Hexa 2D Airfoil meshing" in youtube. It has three parts and is really helpful, although it's just 2d.
Mesh refinement can be done pretty easy in ICEM since you can increase the number of gridpoints on edges quickly.
penetration, phase change, vof modeling |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
HELP! adding a mass source to VOF eqn. by UDF??? | ROOZBEH | FLUENT | 5 | December 3, 2016 17:53 |
VOF mass loss | Smaras | FLUENT | 2 | November 20, 2012 06:36 |
Source terms due to mass transfer in VOF model | ssamton | FLUENT | 0 | March 5, 2012 00:03 |
Mass loss! So what? | jinwon park | Main CFD Forum | 13 | May 22, 2008 09:29 |
