Particle velocity in solid-gas flow
Old   December 14, 2012, 08:00
Default Particle velocity in solid-gas flow
Aisha
3ashoosh is on a distinguished road
Send a message via Skype™ to 3ashoosh
Dear all,
I am running a 2D simulation for FCC riser in ANSYS Fluent 14 using Eulerian multiphase model for the solid-gas flow. I use the standard k-epsolon per phase turbulence model with the standard wall function. The geometry is so simple axisymmetric pipe. The inlet boundary conditions for both phases were coded in UDF .c file and interpreted in the fluent setting up.
When running the case, it converged after 100's of iterations but the outflow particle velocity profile is not parabolic (not fully developed). It decreases slowly from the centre then fall sharply near the wall. Some times has another peak (maxima) near the wall as if it is an annular core flow.
I used no slip conditions for both phases at the wall, also tried different specularity coefficients for the solid phase, but I got same results.
When plotting the wall Y+ value for the solid phase, it changed sharply from 25 to 300 at the inlet then remain between 150 and 160 for the rest of the meters along the wall. And for the gas phase it stays below 20.
I don't know what to do to get the parabolic profile at the out let?
I appreciate any kind of help,
Regards,
3ashoosh
3ashoosh is offline   Reply With Quote
eularian, fluent 14, multi phase, particle velocity, wall function
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
gas solid flow in circulating fluidized bed with different gas velocity kongl1986 FLUENT 2 April 5, 2012 22:23
error message cuteapathy CFX 14 March 20, 2012 06:45
Simulation time for unsteady gas solid flow pandaba FLUENT 1 October 14, 2010 00:04
Moving Solid particle in a flow yigity83 CFX 13 July 14, 2009 08:48
