December 3, 2012, 04:50 |
Modeling a Spray
Anyone with experience with DPM for Spray modeling. please help me out with Modeling Spray. Regards, Vignesh V. |
December 3, 2012, 07:16 |
barzin
Rep Power: 15 |
Hey Vigii
What is the prob? |
December 3, 2012, 07:38 |
Modeling a Spray
Hi Barzin,
The problem is like I have a Solid Cone Nozzle knowing all its working parameters. I don't know how to set the problem for Spray with DPM. The parameters are as follows Cone Angle - 58 Deg Pressure- 1 Bar Volume Flow Rate - 0.44 lpm What should the boundary conditions for the model ?? How to create a model?? How to set up the model with FLUENT?? Will it give a droplet distribution?? Please help me I'm working on my Thesis. Regards, Vignesh V |
December 3, 2012, 09:14 |
barzin
Rep Power: 15 |
Hey bud
I can see that you are quite new to DPM modeling but don't worry at all. it's quite simple to implement but needs some caring at the same time. I would suggest you to look at some tutorial (Evaporating-liquid-Spray), UG and Th.G. In general you need to go to DPM model>Create injection> solid cone> and put the spray point properties there. Model BC needs to have a good understanding of your problem (e.g. define any co/counter flow etc.). your question is rather general so I still don't know what you want to do! but as I said if you can provide me sufficient information, I'd be much happy to help you out with that! Bests Barzin |
December 4, 2012, 10:21 |
Modeling a Spray
Hi ,
Let me start from model. So, that I could clearly define my problem. Consider a nozzle at certain height from a flat plate which is fixed. So, what i did in modeling is i created a cylinder of diameter D=6d and created an another face of nozzle outlet diameter on one base of cylinder. This face is split with respect to volume. I gave conditions like Circumferential surface as pressure outlet Bottom plate as wall inlet face as Velcoity Inlet and other surface at top was given as pressure outlet. Is my conditions are correct. I have already gone through the evaporating spray tutorial . but there was two different fluids under consideration as methane and air at inlets . but in my case there will be only one fluid comes out of nozzle which will be atomized. I hope you got my point . I want some help in loading up the problem in FLUENT. please Help me with this problem. Regards, Vignesh V |
Spray modeling with Fluent | ulalala | FLUENT | 49 | July 23, 2019 00:47 |
Gasoline Spray Modeling | sekkizhar | Siemens | 4 | May 31, 2017 10:23 |
Urea Spray Modeling | David-CFD | Main CFD Forum | 0 | March 31, 2011 22:56 |
Spray Modeling in Fluent | Truckson8347 | FLUENT | 0 | June 8, 2009 11:25 |
how to give pressure as an input in spray modeling | satish | Siemens | 3 | March 7, 2008 20:33 |
