Results of a Flow in a duct, need confirmation |
October 13, 2012, 12:39 |
Hi all,
This is my first time using CFD And below is a result I generated for a simple flow inside a duct. Can someone confirm this looks ok/ appears to be correct? results.jpg Parameters I used are given below Air Velocity - 10 m/s Air Temperature - 20 oC Height of Blocks - 0.04 m Height of inlet - 0.2 m Height of outlet - 0.286 m Distance between expansion & B1 - 0.4 m Distance between B1 and B2 - 0.2 m Length of inlet & expansion/ Length of B2 & outlet - 0.6 m Radius of curved edge - 0.04 m left wall inlet, opposite wall is the outlet two blocks are kept at constant temperature |
December 2, 2012, 19:43 |
Nagrecha R
Rep Power: 13 |
I thin you should ask Dr. Reza about it. He will tell you if it is correct or not?
cfd, result comparision, results |
Display Modes | |
Duct flow | Omar Mohamud | FLUENT | 1 | February 23, 2020 21:33 |
Turbulent flow in smooth rectangular duct - Numerical vs. Literature correlations | marluc | FLUENT | 0 | July 7, 2011 09:23 |
Thin film flow in triangular duct | Swapnil | CFX | 4 | December 4, 2002 16:08 |
Duct Flow | omar | Main CFD Forum | 4 | December 9, 1999 12:43 |
Straight duct flow in CFX 5.2 | Bo Jensen | Main CFD Forum | 3 | November 25, 1998 06:15 |
